Any suggestions for reliable range extenders to fibre plusnet hub One?
dadinthesouth
Trying to get a range extender which will work with a fibre plusnet hub one - TP-link brand items don't appear to be compatible, despite what the company claims - any suggestions?  Thanks
2 REPLIES 2
Strat
Fixes: 565
Re: Any suggestions for reliable range extenders to fibre plusnet hub One?
Moderators Note
This topic has been moved from Fibre Broadband to Tech Help.
dws1900
@dadinthesouth
After trying mains (plug in wall) extenders, routers with lots of antenna's, I finally purchased the BT Whole Home Wifi.
Disable Hub Wifi
Follow instructions
Note I got the dual band version, typically there is now a more expensive tri band version!!
Really depends where you are Wifi wise, ie lots of close neighbours or you live in the country and so not too much wifi congestion.
I have three units which covers a 4 bed property about 15 years old.
If you live in a mansion you may need to get more.
Don't buy the non BT ones which take over your router functions as it will complicate matters.
