Any ideas - using Chrome Canary showing an error.
- Re: Any ideas - using Chrome Canary showing an err...
29-03-2013 9:22 AM
I've posted this query on the Chrome form, but some techies on here may be able to help.
Please see this thread: Link
Many thanks
jim:green link fixed mod:end
Many thanks
5 REPLIES 5
Re: Any ideas - using Chrome Canary showing an error.
29-03-2013 9:25 AM
Link doesn't work even after being fixed - please post your problem
29-03-2013 9:30 AM
The link works here!
Here's the query:
Version 28.0.1455.2 Canary pipe error: 109
Using the above, from today I'm getting a dos box window as attached with a pipe error code. Any ideas how to resolve this? Using the latest Chrome beta works fine, but not the latest Canary!
Here's the query:
29-03-2013 9:38 AM
It works because you are logged in or registered I believe
30-03-2013 9:38 AM
I can't help with the question but the link works for me. (not logged in or registered)
30-03-2013 10:56 AM
Thanks - problem resolved. The dos box shown is used for bug detection in the Alpha of Chrome called Canary.
