Any iPhone experts here? - we have a member with problems
- Any iPhone experts here? - we have a member with p...
08-05-2015 7:05 PM
We have a new user that seems to have some problems with an iPhone (& maybe a Windows phone - the latter may be an incorrect assumption on my part).
The issues were posted here and as far as I know has not been resolved. Ignore the IP address aspects that has been resolved, but whatever the issues with the phone(s), it seems to be causing Wimpywoo to have all sorts of problems based on subsequent posts. Some of these are no doubt due to a lack of detailed technical knowledge, but I suspect problems with the phone(s) - maybe a virus still present, is the root cause of the issues.
I believe the user needs guidance to remove the unwanted email address, backup vital data (without any virus related issues) and remove any virus.
I'll try and get Wimpywoo to post here in this thread if anyone thinks they can help, I'm afraid I know nothing about iPhones.
Re: Any iPhone experts here? - we have a member with problems
08-05-2015 7:09 PM
08-05-2015 7:12 PM
York.
08-05-2015 7:17 PM
08-05-2015 7:21 PM
Quote from: chenks76 iPhones can't get "viruses" so not sure where you got that notion from.
Try reading Wimpywoo's post
As I said I know nothing about iPhones
They clearly need some help to be able to use the phone correctly any remove that unwantred email address that could be syncing with things it shouldn't, whatever, I don't know. Perhaps those of you that can help can post some sensible instructions.
08-05-2015 8:14 PM
08-05-2015 9:23 PM
You can then reinstall the Operating System, but you will need a PC with iTunes installed!
Have you reinstalled Cydia? If so, then the phone is Jailbroken!
York.
08-05-2015 10:18 PM
09-05-2015 8:11 AM
phones don't get "viruses".
09-05-2015 9:59 AM
09-05-2015 12:05 PM
Quote from: chenks76 phones don't get "viruses".
as a generalised statement, especially as no other helpful advice has been posted by chenks76. Malware might be a better generalised term to use and I understand that some FREE apps can contain malware (so not a virus in the traditional sense) and the most obvious solution to that is to remove these apps to start with.
09-05-2015 12:10 PM
09-05-2015 12:46 PM
09-05-2015 12:51 PM
09-05-2015 12:55 PM
