Any Open Office users out there?
- Any Open Office users out there?
22-02-2015 8:35 PM
I'm running Win 7 Ultimate 64 bit.
Any input/advice/horror stories would be most welcome.
York.
Re: Any Open Office users out there?
22-02-2015 9:02 PM
As ever, it depends on what you need to do with it.
22-02-2015 9:05 PM
If you're not after major compatibility and mainly using it for your own use it should be fine
22-02-2015 9:08 PM
I have a copy of Outlook for my email and have had more problems with it than Libre Office.
22-02-2015 9:30 PM
Quote from: NedLudd Mine is Office 2007!
And? Mine is Office 2003......
(If it ain't broke, well, excluding the fact it's a permabroke MS product of course!!)
22-02-2015 10:12 PM
and the only time I use Libre Office is for csv files with too many rows
Off Topic
I still haven't found whether Office 2003 will work with Win 10
22-02-2015 10:20 PM
http://www.ksosoft.com/product/office-free.html
Regards
Mike
22-02-2015 11:34 PM
then along came Open Office... and it opens the originals no problem.... I also use Open Office for a spreadsheet /list that I need to continually update.. and have no problems with that...
on the whole... OO and LO work... ... as a bonus... if you are passing files of docs on to someone who uses Linux.. it is compatible .... both ways...
23-02-2015 7:23 AM
I have tried both OO and LO having installed each in turn on my mother's PC. Both worked well and quite easy to adapt to from Office.
I think that if I had to re-install 2007 but lost the original disc I would probably move to LO.
Forum Moderator and Customer
23-02-2015 8:14 AM
I tried various O Office software but I couldn't get on with any of them. If you only use them for basic letter writing etc I found they were fine but I need mine to do mail merge as the like and just couldn't get them to connect to excel to consistent standard.
23-02-2015 11:57 AM
23-02-2015 7:24 PM
I've passed over your help to the Financial Services Manager who is now mulling them over. Quite why she needs to mull over free software I haven't a clue!
Once again, many thanks for all your help!
York.
23-02-2015 8:54 PM
I've given up on Base (the database) as it just doesn't seem to work properly. Issues not resolved by the ever helpful forum folks either.
Few formatting glitches with Word if sharing.
Think pivot tables work differently from Excel as well. Couldn't get mine to run.
I started with enthusiasm and gradually wandered away.
Libre seems to interfere with other OpenOffice docs as soon as you open it (Libre). Not sure what's going on there. Can anyone confirm this?
28-02-2015 1:51 PM
