Any Happy Campers ? Advice on powering TV & SKY+HD Box using a 12v-240v inverter
Re: Any Happy Campers ? Advice on powering TV & SKY+HD Box using a 12v-240v inverter
I applied a more realistic profile to the Run Time test.
I turned off the TV at 2 hours, and continued with the SKY+HD and other PVRs being powered, ie recordings.
At 8 hours, I terminated the test, with the battery voltage under load being 12.08v
