Antivirus packages - Any recommendations, please
Interested
Have been using McAfee antivirus, firewall & spam & privacy protection until recently for almost 3 years as a satisfied home (domestic) customer. But am now very disgruntled with their customer services/ technical support and seriously thinking of switching early, despite having a valid subscription for another 4 months.
Have trialed AVG for nearly 30 days now but am not convinced due to most automatic updates failing and manual updates inside normal office hours also fail regularly! Though my computer is now much faster than with McAfee.
Have read recommendations for Avast.
Visited Norton's website though must admit  wonder if it is worth the extra cost.
Any experiences much appreciated. Smiley
With thanks.
Fixes: 50
Re: Antivirus packages - Any recommendations, please
Current free version of AVG gets good reports, better than some paid for packages.
Personally I've used Kaspersky for over3 years with no problems and it consistently gets high marks in group tests.
Customer and Forum Moderator.
StickyMick
Norton isn't much better than McAfee for resource hogging, IMO. But any A/V software will take up some CPU time.
Try giving Avira antivir a look: http://www.free-av.com/. They do a free and a paid for version.
I use AVG Free and am happy with it.  There are times when it won't automatically update and this is annoying but at least you get a warning and have the opportunity to update manually.
Fixes: 50
Interested has actually asked a difficult question as if this thread runs long enough recommendations will be put forward for most if not all A/V products.
Also if a selection of group tests is consulted a variety of conflicting results will emerge.
No single package will give total protection but some offer a close second and hopefully the OP will pick one of these.
Similar threads have run in the past here with similar results.
The best of luck Interested  Smiley
StickyMick
As I always say "An A/V package is only as good as it's last update". So the reaction speed of the programmers to new threats should also be taken into account when choosing a package, as well as the availability of update servers.
jazz
I switched from McAfee to Avast! about 3 years ago and have been delighted with it.  Be aware though that if  you try to get rid of McAfee it does not just go with using Windows Uninstall (or the McAfee Uninstall either!). After using the Windows uninstall you need to go to http://download.mcafee.com/products/licensed/cust_support_patches/MCPR.exe and dowload and then run the MacAfee removal tool (MCPR.exe).  This will remove all traces - if you don't do this then it can interfere with future AV packages that you may use.
Fixes: 50
Similar situation with Norton.
You beat me to it Strat but yes you are right about Norton.
And sometimes with AVG too.
Recently had to run the AVG removal tool before Kaspersky would install.
thejudge
I've been using Avast! for about 6 years now, both on my old 98SE rig and my newer XP setup. I can't recall ever having any problems with it apart from the occasional failed update on the 98 machine.
As for updates, Avast! updates at least once every day - sometimes more often.
If you do decide to use it, though, make sure you disable the sounds!
jazz
I like the sounds!!  It's reassuring to hear that the update has been completed Wink
I like the Avast sounds too, for the same reason. Was interested to hear favourable opinions about Kaspersky because I have heard opposing ones. Also, my bank is offering the ISS very cheaply after a 30-day trial. I think that I was a little disturbed due to it being Russian!
Had not gone for the offer because of the reports about it being resource hungry and difficult to master.
Interested
Quote from: jazz
Sorry, Jazz The link does not work.
Will try again by logging into my account in McAfee an attempt to find it.
Cheers all for the info so far.
dgreen007
Quote from: jazz
I have a feeling I may have to find a specific uninstall software as when I'm trying to install AVg free it comes up telling me that I already have an antivirus software running on my PC but I have no idea what it is referring to.
Is there any way you can actually find out what exactly is still running on your PC even if you can't see it in the remove/add facility in Windows.
