Anti Virus Program
- Anti Virus Program
Anti Virus Program
09-04-2013 5:19 PM
Re: Anti Virus Program
09-04-2013 5:21 PM
09-04-2013 5:24 PM
Forum Moderator and Customer
09-04-2013 7:40 PM
You could uninstall avast - go to the website - and re-download the latest version... proceed from there ...
09-04-2013 9:48 PM
10-04-2013 8:40 PM
http://chart.av-comparatives.org/chart1.php
http://www.av-comparatives.org/comparativesreviews/detection-test
http://www.av-test.org/en/tests/home-user/windows-8/janfeb-2013/
I use Kaspersky which costs about £6 per year (I buy two 3 user licences)
11-04-2013 8:54 PM
You can also get updates on most days so it not bad for free, it also got a link scanner so it tells you if the site is bad
http://free.avg.com/gb-en/homepage
11-04-2013 10:11 PM
I was a great advocate of AVG from 3.5 to about 7, when it did start to slow down the startup and the scanning took forever... so I switched to AVAST... and hardly know it is working, except when the popup for the update tells me..!... also it has a link scanner too !...
11-04-2013 10:39 PM
Quote from: shutter I was a great advocate of AVG from 3.5 to about 7, when it did start to slow down the startup and the scanning took forever...
That is my experience too. The slow-down is very marked for older computer with less RAM; on a new machine you probably wouldn't notice anything.
11-04-2013 10:42 PM
This Newsletter is a great read
"A dozen tools for removing almost any malware"
https://windowssecrets.com/top-story/a-dozen-tools-for-removing-almost-any-malware/
Regards
Mike
12-04-2013 8:08 AM
but it is no good to just rely on one to do everything , its more of a combination, my own choice is ,MSE + Malwarebytes + Ccleaner
12-04-2013 8:45 AM
12-04-2013 10:10 AM
Quote from: Oldjim I use Kaspersky which costs about £6 per year (I buy two 3 user licences)
So you must mean £6 per machine per year or £36 per year for your 6 licences?
12-04-2013 10:16 AM
13-04-2013 7:17 AM
