Another critical Java vulnerability puts 1 billion users at risk
- Re: Another critical Java vulnerability puts 1 bil...
26-09-2012 4:36 PM
Quote Just as Oracle is ramping up for the September 30 start of JavaOne 2012 in San Francisco, researchers from the Polish firm Security Explorations disclosed yet another critical Java vulnerability that might “spoil the taste of Larry Ellison's morning…Java.”
If you disabled Java when the last zero-day exploit was spotted in the wild, then you might consider doing so again . . . or dumping Java altogether? According to Security Explorations researcher Adam Gowdiak, who sent the email to the Full Disclosure Seclist, this Java exploit affects “one billion users of Oracle Java SE software.”
http://blogs.computerworld.com/malware-and-vulnerabilities/21056/another-critical-java-vulnerability...
Re: Another critical Java vulnerability puts 1 billion users at risk
26-09-2012 10:10 PM
27-09-2012 6:40 PM
Question.....
What do you replace it with, as so many things rely on us having Java installed. ?
27-09-2012 7:13 PM
27-09-2012 10:36 PM
28-09-2012 6:43 PM
Quote from: ejs I can't think of much that requires Java.
So.... does that answer my question.... no...
can you do without it? if you think so little requires java...?
or what is your alternative suggestion to java?
28-09-2012 7:24 PM
I haven't bothered to select another bittorrent program, there are plenty to choose from, but I don't really use azureus anymore anyway.
Having an alternative for Java itself doesn't really make any sense. Unless you mean an alternative for developing software, then which programming language you might choose instead would depend on what you were developing. I wouldn't have thought many people developing a new website these days would decide to use Java applets for anything.
What are all the irreplaceable Java programs and Java applet using websites you use then?
29-09-2012 1:48 AM
29-09-2012 8:45 AM
Alternatively, install the 32-bit and then in Chrome enable the "click to run plugins" feature and in Firefox install NoScript. These are also helpful for other plugins with less than stellar track records, e.g. Adobe Flash, QuickTime etc.
29-09-2012 10:41 AM
I do not know what the "threat" is to me, with Java installed,. and most of the techy stuff about threats is beyond my comprehension.
I suppose it is a bit of "head in the sand",.... but if the guys who make Java, know about "threats" to users, then it is their job to counter that and issue, or automatically, update as and when needed.
To post something about a "threat" and say that it should be removed for your own safety, without a simple guide to reasons why it is a threat, is likely to cause panic amongst users...
Hang on a mo... isn`t that what Linux users say about Windows? it is insecure, and threats abound almost daily... perhaps I should uninstall that too... (cant get on with Linux so end of story ! ! !)
29-09-2012 4:01 PM
29-09-2012 5:21 PM
Where did you read that?
Quote from: shutter To post something about a "threat" and say that it should be removed for your own safety, without a simple guide to reasons why it is a threat, is likely to cause panic amongst users...
Quote To recap, this Java bug is even worse than the last critical Java vulnerability. It puts one billion users of Oracle’s Java SE, Java 5, 6 and 7, at risk. It could be exploited using these browsers: Chrome, Firefox, Internet Explorer, Opera and Safari. If you visit a maliciously crafted website, attackers could gain total control of your PC. Wow, thanks a lot Oracle.
29-09-2012 8:41 PM
and followed up by......
Does that look familiar?
30-09-2012 12:02 AM
30-09-2012 10:00 AM
