Another External Hard Drive query.
Fixes: 9
It takes approx 6 minutes for me to transfer 70 photographs from my computer to my external hard drive, is this normal ?
Details are  1.50GB of Photos in RAW format.
Speed Transfer 4.04 Mb/sec
Fixes: 62
Re: Another External Hard Drive query.
Is it connected via USB or eSATA
Fixes: 9
Connected by USB
Fixes: 62
32 Mbps seems a bit low but there may be other limiting factors such as your antivirus scanning the data transfer
pierre_pierre
is it USB 1 or USB 2  (And it needs USB2 leads)
Fixes: 62
You couldn't achieve the speeds reported on USB1
pierre_pierre
sorry didnt look that close
Fixes: 9
That's not like you.
