Another Comodo query
Fixes: 9
Comodo came up with the message system 32/services.exe.. terminated with status code 0.
The computer then shut down, restarted with no further messages.
Did a thorough scan with Avast and got the message.. no infected files found, however there was a long list of files that Avast said it could not scan.
Internet search indicates that system32/services.exe is a trojan
I Would be grateful for any advice about this & how I can check out my system (free if possible) to see if there are any nasties lurking there
Avast, spyware terminator,comodo BOclean,super antispyware & Comodo firewall are always running when on line.
1 REPLY
pierre_pierre
Re: Another Comodo query
try http://www.malwarebytes.org/ highly recommended
