Annoying message
cuvol
Annoying message
I have just replaced my HP Deskjet 840c printer and HP 3400 scanner with a Brother 3 in 1 device.  As I no longer require the software on my computer for the 2 HP Devices I used the Add/Remove Program utility to un-install the software.  However, I now get an annoying message box popping up which relates to the scanner. The title bar of the message box Says "HP PrecisionScan LTX SetUp", and the message says "No Digital Signature". See Attached image.
How do I stop the message box popping up.  I've done a thorough search, through the Windows Explorer, and deleted all references to HP.  I've even searched through the registry using Edit/Find, and deleted all references to HP.  I've run two separate registry cleaners to fix any errors. But I'm still getting the message pop up.  Is there anywhere else I should be looking?
Njal
Re: Annoying message
See HP PrecisionScan LT Setup PopUp:
http://forums11.itrc.hp.com/service/forums/questionanswer.do?admit=109447626+1242987664853+28353475&...
Also:
http://www.annoyances.org/exec/forum/winxp/1056124289
Hell's bells, what a performance to get rid of a printer!
Regards,
Neil
Fixes: 62
that is one reason I won't touch HP printers - the other one was when the connection was via the parallel port and the software totally blocked getting a second printer to work
