Annoying arrows
- Re: Annoying arrows
Annoying arrows
16-09-2012 1:09 PM
Every now and then I try to remove the ugly overlay short-cut arrows on desktop icons in Win 7.
A software routine exists to remove them that was designed for Win Vista, and I have used it successfully in a Win 7 that was upgraded over Win Vista. However, it doesn't work in straight original Win 7.
Anyone know of a Win 7 routine to achieve arrow-less icons?
3 REPLIES 3
Re: Annoying arrows
16-09-2012 1:18 PM
Does this help?
http://answers.microsoft.com/en-us/windows/forum/windows_7-desktop/removing-shortcut-arrow-tweakui-f...
The blank ico looks a safe option
Re: Annoying arrows
16-09-2012 1:23 PM
This is the easiest one I could find for you,
http://www.blogsdna.com/2064/how-to-remove-windows-7-shortcut-extension-and-shortcut-arrow-icon.htm
The only icon I have on my desktop is the recycle bin so it doesn't affect me.
Edit :
I just read a few reviews and most people say this doesn't work.
Edit :
Re: Annoying arrows
16-09-2012 4:41 PM
Never tried this myself but maybe http://www.mydigitallife.info/workaround-to-remove-shortcut-arrow-make-transparent-in-windows-7-yet-...
