Android update 5.0
- Android update 5.0
Android update 5.0
28-06-2015 5:36 PM
Is it wise to install new updates on Android if everything is currently working ok or do these updates include security updates ?
Re: Android update 5.0
28-06-2015 6:02 PM
28-06-2015 7:01 PM
Installed it,
some message appeared saying it was flashing the boot up or something.
Seems to work fine since upgrade.
28-06-2015 9:29 PM
Quote from: gleneagles Tablet has automatically downloaded (but not installed) 5.0 software update, I think the current version is 4.4
Actually 5.1.1 "Lollipop" is the current version, though 5.0 is the first version of Lollipop, released back in November...
29-06-2015 9:14 AM
it depends on the manufacturer as to which is the most current version they have made available.
29-06-2015 9:42 AM
29-06-2015 2:44 PM
And for the record my S5 is on 5.0 with the Three version of the OS release...
29-06-2015 3:24 PM
08-07-2015 4:38 PM
If you experience browsing problems it's because some cache files don't like Lollipop, so delete the cache regularly.
08-07-2015 6:43 PM
And I'm using 5G from an Asus router.
08-07-2015 6:57 PM
