Android to PC
rongtw
Fixes: 12
Android to PC
anyone have any suggestion for PC software free , which allows me to save and update contacts ETC .
yes i know some manufacturers have some but i need a universal one Thumbs_Up
6 REPLIES 6
Mav
Fixes: 515
Re: Android to PC
Check out MyPhoneExplorer.
You also install an app on the phone and it works well. I have been using it with my Android phones for a number of years.
Forum Moderator and Customer
Fixes: 1,483
Re: Android to PC
If your contacts are linked with your google account you can go to contacts.google.com and view them there.
Browni
Aspiring Hero
Fixes: 60
Re: Android to PC
Outlook.com
Fixes: 395
Re: Android to PC
Airdroid https://www.airdroid.com/
Connect to the phone via Wifi using a standard browser, will do File access, contacts , SMS etc . In fact just about anything...
rongtw
Fixes: 12
Re: Android to PC
@dvorak it was Google account the reason i decided to look for a software , yes its good BUT ,,,,,, wife's phone is linked to my account as is young lads .
This had messed up all the contacts as they got mixed up Sad  as all 3 phones synced and i had lost some numbers .
That's fixed now i separated the google accounts Thumbs_Up
So thought would look for a PC based backup as a fail safe Wink
Will have a play with ones suggested Smiley  thanks @MisterW @Mav
Mav
Fixes: 515
Re: Android to PC
@rongtw
With MPE you can connect via USB, WiFi or Bluetooth. It also allows you to easily send SMS using the PC for easier typing as well as checking memory, battery, etc and a lot more, too.
