Android - finding the USB on the desktop
- Android - finding the USB on the desktop
11-05-2014 4:35 PM
I have ES file manager app installed, and need to scroll down a menu to locate the usb device... is there any way I can put an ICON directly linked to the USB stick ? or is the ES File manager route the only way to access the content of the USB memory stick...?
Re: Android - finding the USB on the desktop
11-05-2014 6:24 PM
Mostly Android is app driven not event driven. So a music player will look in the folders you have setup, same with a pic viewer.
Can't say I have ever made a shortcut on the desktop for something like that, apps yes, I like mine bare.
11-05-2014 6:55 PM
I must comment, that , although I have asked a few questions about Android on here.. I am not as frustrated using it, as with Linux .... It does seem to be much simpler to use, and the apps "just work" !
12-05-2014 9:56 AM
12-05-2014 10:55 AM
12-05-2014 11:00 AM
Wrong
Quote from: Hairy ONLY because you can't install any M$ software on it
http://office.microsoft.com/en-gb/support/set-up-and-use-office-365-on-your-phone-or-tablet-HA102818...
You can if you really want to
12-05-2014 11:30 AM
12-05-2014 11:34 AM
http://www.geekwire.com/2014/microsoft-confirms-making-office-android-tablets/
Quote “Let me tell you conclusively: Yes, we are also building Android native applications for tablets for Word, Excel and PowerPoint,” said John Case, a Microsoft Office corporate vice president for marketing, in a follow-up interview with GeekWire this afternoon. “We haven’t picked a date that we can stand behind yet, but they’re coming. We are committed to doing it.”
Not yet but it is coming and then you can enjoy the benefits of MS on your tablets or
I wasn't sure which smiley was appropriate so put in two options
12-05-2014 12:27 PM
This is what he wants Linux to do, be a better M$, not going to happen
12-05-2014 2:31 PM
12-05-2014 4:17 PM
Quote from: shutter I must comment, that , although I have asked a few questions about Android on here.. I am not as frustrated using it, as with Linux .... It does seem to be much simpler to use, and the apps "just work" !
All my LINUX apps work fine BTW
