Android email client
Mav
Fixes: 515
Finally got a tablet that I am happy with and seems to work well...
I had decided on a Samsung Galaxy Tab 3 8" as it seemed to meet all my needs but nowhere had it in stock as it is discontinued. I liked the 4 7" but it didn't support MHL. So, after much deliberation I got the Acer A1-F840FHD (Android 4.4.2). Even got vouchers worth £20 from Argos which will be handy towards SWMBO birthday present next month.
So far so good but have a small problem:
The built-in email client doesn't allow links to be clickable which seems a tad daft (have checked all settings I can find) so wondering if there are any recommendations - don't want to use g-mail?
Forum Moderator and Customer
21 REPLIES 21
w23
Fixes: 4
Re: Android email client
You may find that 'tap and hold' on the link gives a copy option and a similar 'tap and hold' in the address bar of the browser should give a paste option, not quite the same as a clickable link but it may suffice.  You could also try webmail in your browser, the links may then be clickable.
Call me 'w23'
Fixes: 1,483
have a look at mailbox (https://play.google.com/store/apps/details?id=com.mailboxapp)  or bluemail (https://play.google.com/store/apps/details?id=com.trtf.blue&hl=en)
Mav
Fixes: 515
@w23 Links in Webmail are clickable but I prefer to use an email client if I can.
Tapping and holding gives a highlighted section of the link with the need to drag the two blue tabs around which is quite fiddley  Sad
@dvorak will check those links out.
Thanks Smiley
TORPC
Quote from: Mav
Even got vouchers worth £20 from Argos which will be handy towards SHMBO birthday present next month.
Thats a great way to save a few pennies for beer Smiley
There may be an option to allow the links to be clickable, as I feel it may be a security feature
Mav
Fixes: 515
Have checked the security settings to no avail.
A Google search seems to indicate this is quite a widespread issue within Kitkat.
Mav
Fixes: 515
@dvorak Had a look at the two email apps...
The first is for gmail and iCloud and the second doesn't support pop3 yet.
There's a plethora of apps in Play Store that's why I was wondering if anyone has any recommendations based on use?
pwatson
I use K9Mail and find it very reliable - Links work fine Smiley
RPMozley
Fixes: 13
Another for your consideration is MyMail. Supports POP3 and IMAP, although not sure why you want to use POP3 but no matter.  Tongue
That's RPM to you!!
Mav
Fixes: 515
Thanks for those, I'll look shortly.
I am used to pop3 with Outlook for the last 15 or more years and see no need to change as it suffices for my needs Smiley
ITWorks
Fixes: 9
Quote from: pwatson
+1
Regards
Mike
Mav
Fixes: 515
Just checked out the reviews and it does well so have downloaded it it.
Will set it up either later or the 'morrow Smiley
Thanks.
WTF
Have you tried the vanilla android email client (i.e. Google's, not Acer's)?  Links are definitely clickable in it.
I have a Nexus and my hotmail and gmail work fine with it.  Setting up was a breeze, too: it supports many common email providers so no faffing around finding servers, ports and the like.
Mav
Fixes: 515
You obviously don't mean GMail. I searched PlayStore and couldn't see anything that appeared to match your description. Do you have a name or link for me.
While K9 does the job it's got some restrictions and isn't as easy to use as I'd like.
DaveyH
Champion
Fixes: 12
Its just called email and its the default app which is pre installed on Android. Don't think its actually available on Play and wondering if Samsung have replaced it with their own bloat.
