Android USB Debugging
morgan2476
Has anyone got any ideas why I have to use USB debugging to connect both my Android devices to my PC?  All other usb devices are OK.  I am using windows 7.  Thanks.
4 REPLIES 4
Fixes: 395
Re: Android USB Debugging
Most USB devices e.g Memory sticks support USB 'Mass storage mode'. Earlier Andoid devices also supported this, whereas modern ones use MTP or PTP mode ( see this for explanation http://www.howtogeek.com/192732/android-usb-connections-explained-mtp-ptp-and-usb-mass-storage/ ). When in PTP/MTP mode your PC will see the device as a camera rather than a disc. When you enable USB debugging it causes a different USB PID/VID to be used by the device , which does support Mass storage mode
morgan2476
Thanks for that link.  I am assuming that everything should be ok by enabling USB Debugging.
chenks76
All Star
Fixes: 12
it poses no risk unless you connect your device to a system that you don't trust.
Fixes: 395
USB debugging enabled is seen as a potential security risk by some AV software. In reality it's only a risk if connected via USB to a malicious system so in reality it's not a risk. Take a look here for some explanation http://www.howtogeek.com/177444/4-geeky-tricks-that-reduce-an-android-phones-security/.
If you want to transfer files easily between a Windows PC and an Android device, take a look at Airdroid https://play.google.com/store/apps/details?id=com.sand.airdroid&hl=en_GB . You run it on the device and then can transfer files ( amongst other things ) using a browser on the PC.
