Android OTG questions
- Re: Android OTG questions
- « Previous
- 1
- 2
- Next »
29-12-2020 2:31 PM
They've crossed again! See my previous post regarding pins used for charging.
29-12-2020 2:33 PM
@Baldrick1 i did and mentioned in my fist line !!!!!
29-12-2020 2:41 PM
Have you seen the slide switch labelled Charge/OTG, presumably either/or, not both similtaneously?
29-12-2020 3:13 PM
@Baldrick1 Hmm... yes.. I saw t hat on another seller pics ! ! !... so it could be more useful than my current setup. as you say,.. either/or... but not both at same time... Presumably, that switch disconnects the USB side of the unit, Probably, this is as a "safety" measure, so that no equipment , mostly, the tablet/phone, is not damaged......
At least it would save me having to unplug and plug up... and could be charging during "quiet use" when the touch screen could be used..
29-12-2020 3:48 PM
The switch possibly works the mode select option, see https://pinouts.ru/PortableDevices/micro_usb_pinout.shtml
My only other query relates to the rather strange chargins connection arrangement described in the manual referenced earlier. It will be interesting to see if you get a reply from China.
It did amuse me to read on the sellers page that they will return your £3.89 if you ship the item back to China at your cost within 30 days!
31-12-2020 11:30 AM
Nothing from China, so far... it`s almost 48 hours now... they must be celebrating New Year early ! ! ..
31-12-2020 12:19 PM
Make that Very early! https://chinesenewyear.net/
01-01-2021 12:25 PM
@shutter wrote:
Been looking further into this on Ebay... and find this item
which,.... seems to fit the bill.... however a "similar" device mentioned that it was not a "through" power supply for charging the phone/tablet. so I have asked the seller for clarification.
Well, I never got an answer back.... but .... I did "make an offer" and it was accepted, so I ordered it...
On sale price.... £4.67 free postage
Offer price £ 3.25 free postage .... so not a bad deal really ! ... will report back when it arrives....
(I noted that there is a 3 port version... {cheaper price} I.E.. Only 2 USB ports and 1 OTG port..... but 3 will be good for me..)
- « Previous
- 1
- 2
- Next »
