Android - Desktop background pic
shutter
Fixes: 64
I found an app to have a "certain young german lady" as the background for my Android Tablet.... but wonder if there is a way of using my own pics....... as in Windows.. " set as background/wallpaper"......  Undecided
7 REPLIES 7
Fixes: 1,480
Re: Android - Desktop background pic
Go to settings, display, wallpaper
You should be able to select one
shutter
Fixes: 64
Yeah, But...... I want to use my OWN pics.... not those supplied, or on and app ... so how can I do that?  Huh
avatastic
Depending on the version of Android, you should just be able to long-press on a home screen and get the option to pick from your gallery.
F9 member since 4 Sep 1999
F9 ADSL customer since 27 Aug 2004
DLM manages your line the same way DRM manages your rights.
Look at all the pretty graphs! (now with uptime logging!)
shutter
Fixes: 64
Thanks... I`ll give that a go tomorrow...
G`night..  Kiss
Fixes: 1,480
On the method I shared, that has an option to select from the gallery for my android device
shutter
Fixes: 64
OK guys... thanks for the help... have managed to get a couple of pics sorted and displayed...  Wink
Fixes: 1,480
glad to hear Smiley
