Android 5 Lollipop update.
nozzer
If you are using a Nexus machine of any kind, and you get a prompt to update to this new version of Android, DON'T, at least not until this has been fixed. You'll probably end up with a bricked wi-fi like mine has if you do!!
http://www.phonesreview.co.uk/2014/11/14/nexus-users-reporting-android-5-0-lollipop-wifi-problems/
11 REPLIES 11
Razorback
Re: Android 5 Lollipop update.
Yikes! Thanks for the heads up Smiley
nadger
Thanks nozzer  Smiley
Not updated my Nexus7 ( 2012) as yet so will delay.
twocvbloke
Lollipop?? I've not even had a break to have a KitKat yet.... Shocked
Fixes: 1,483
Flashed my nexus 4 and have had no wi-fi issues at all. running really well.
godsell4
No such issues with my Nexus 7 (2012)
3Mb FTTC
nozzer
Temporary workround...  select any wifi channels other than 12 or 13.
@ dvorak & godsell, are you using other channels?
godsell4
On channels 1 or 7 I think both at home or the office.
3Mb FTTC
Fixes: 1,483
12 at home, no idea in the office or on other hotspots.
journeys
12 works for me (on lollipop - nexus 7), update worked fine, all apps appear OK
nozzer
It's apparently affecting some machines and not others. Not sure Google understand why just yet, hence the delay in issuing another update.
journeys
Quote from: journeys
except for skype , not working correctly
