Android - 32Gb TF card storage
shutter
Fixes: 64
Got me a nice new 32Gb TF card and SD card adapter from 7 day shop... have put half my music vids onto it on my laptop... put the TF card in the slot in the 7" tablet... but can`t seem to find it anywhere.....
Any help in locating it... ( yeah, I know it is in the slot in the side of the tablet )..  Roll_eyes  So I can access the 15Gb of music on there.....
Thanks.
3 REPLIES 3
Fixes: 1,480
Re: Android - 32Gb TF card storage
have you got astro file manager installed? if not that should show you all the storage devices etc.
shutter
Fixes: 64
don`t seem to have a file manager.... well not noticed one !...
However, I have now found the vids... showing as pics of the first vid in each folder... would prefer to have plain folders with names on , in a reasonable sized font so I can read them !!!...  ... do I need an app to make that happen?  if so, any suggestions?
shutter
Fixes: 64
Tried Astro File manager... and another one... not happy.. so will look at others.... thanks for pointing me in the right direction ! . Wink
Have found one...!... ES File Explorer  .... does the job ...  Wink
