And who said mains voltage it 240V LoL
- And who said mains voltage it 240V LoL
Re: And who said mains voltage it 240V LoL
12-05-2008 2:38 PM
Quote It's known as equi-potential earthing
Which backs what I have posted.
Edit: We could be disagreeing because of terminology. Earth bonding is necessary because of leakage current to metal work. The source of leakage current is not just confined to faulty appliances.
12-05-2008 6:48 PM
Quote from: itsme The main reason for earth bonding is that ...
But to stoke up the argument up a bit: I've always understood that the equi-potential part of the earthing equation is simply to do with ensuring miscellaneous bits of metalwork are all connected to a known reliable electrical system common earth point, in order to comply with Institute of Electrical Engineers regulations, which require that any metal parts of a building that could become live should are earthed. (Rather than relying on the natural earthing of the building structure and the land it stands upon, which may be of variable quality.)
In a nutshell, it's no longer enough to ensure your appliances are all earthed, you practically have to ensure that your entire building is earthed to the electrical distribution network.
12-05-2008 9:45 PM
12-05-2008 9:54 PM
Anyway, my house has a 2-cable overhead supply which is of course live and neutral.
We had some "questions" over earthing a few years back - had been the usual clamp on the water main job.
Anyway, it turned out earthing was actually OK but the local "wiremen" came round and just connected a sodding great cable between my earth and the incoming Neutral.
As proved by an earth loop test this was perfect, so I asked for an explanation. They said on the 2-phase supply live was live but neutral was earthed at every alternate telegraph pole by a very big long spike!
13-05-2008 12:23 AM
Its failure modes require additional precautions like those you've described. They may also have used special co-axial supply cable designed to make sure that the live wire breaks before the neutral wire if your supply cable gets damaged.
15-05-2008 10:18 AM
Going back to my 'Electro Tech' days if I remeber correctly, power is generated in this country as a 3 phase. For heavy duty machinery, keeping things simple, a 3 phase supply is used allowing connection across the phases. For domestic use, a connection is made between line and the centre of the 3 phase star as it is known. However, although the nominal 'voltage is 240 (230v) phase to neutral, that is the RMS value. i.e. the equvalent DC voltage. In fact the voltage rises well above 240v but also falls to 0 so the effectve voltage is 240v. If you measure the peak it rises to about 340v peak if I have done my maths right. We use alternating voltage for, debateably, 2 main reasons. Firstly is allows easy conversion from 1 voltage level to another - a transformer - and secondly it gives 100 chances a second to let go if you connect yourself across the potentil. A direct current would cause your muscles to seize locking you to the live thing you are touching.
15-05-2008 1:22 PM
As has been said - the neutral is at a constant zero (or nearly) to earth.
The live does go from - to +ve
Three phase is 440 volt
15-05-2008 4:11 PM
Quote from: pierre_pierre your answer is completely wrong, it is virtually impossible to let go of a live wire.
Not true - if the current causes your muscles to contract, so that contact is broken, it is virtually impossible to hold on to a live wire.
15-05-2008 5:16 PM
Quote from: briston However, although the nominal 'voltage is 240 (230v) phase to neutral, that is the RMS value. i.e. the equvalent DC voltage.
The RMS value is not an equivalent DC voltage. Strictly, it's an average voltage that causes equivalent average power consumption when feeding a purely resistive load.
Apart from that it's nothing like a DC voltage. Its instantaneous voltage is still going from +240 RMS to -240 RMS relative to neutral/earth at 50 times a second for a start. But you are right in mentioning that the peak voltage of each transition of the sine wave is about 340 Volts (+340 to -340 that is). My ancient copy of Scroggie's Foundations of Wireless and Electronics helpfully explains that peak AC voltage is 1.414 times the RMS value.
Quote from: briston We use alternating voltage for, debateably, 2 main reasons. Firstly is allows easy conversion from 1 voltage level to another - a transformer - and secondly it gives 100 chances a second to let go if you connect yourself across the potentil. A direct current would cause your muscles to seize locking you to the live thing you are touching.
I'd say that whoever told you this was winding you up. There's no way your brain and and muscles would react quickly enough during the millisecond or so around each zero-transition.
We use AC power because it's more efficient to transmit electricity over very long distances at extremely high AC voltages. But as you suggest, using AC does then make it easier the convert this high voltage to lower voltages for consumption. A secondary benefit of AC was to provide a time-standard for time-keeping. It's less important these days because better time-standards are available, but in the past the mains frequency was maintained very accurately at 50 Hz for this purpose. For example, years ago most of the street lamps would have had an electric time-switch that depended on the mains frequency. They use dusk and dawn light sensors these days, I believe.
22-05-2008 2:23 PM
Quote from: itsme Also BT 'live' is -50v
Yep. It is to increase longevity of their wires.
You may remember from Chemistry lessons something called REDOX (No not for a soapy bathtime experience!), during any chemical reaction there will be some atoms that loose electrons and some that gain electrons, the loss of or 'reduction' in electrons is called oxidation. A REDuction in electrons if OXidation. We commonly call this rusting and corrosion. By charging a wire with 'negative volts' you can reduce the amount of oxidation.
On big metal hulled ships, they do the same thing with a large piece of zinc strapped to the hull called a 'sacrificial anode'.
SW.
3Mb FTTC
22-05-2008 2:40 PM
22-05-2008 7:34 PM
Quote from: axisofevil
Also with heat hense the reason that you are taught when feeling your way out of a burning building to use the back of your hand.
22-05-2008 10:18 PM
22-05-2008 10:22 PM
Not too painful in the circumstances - but still not something I'd recommend.
23-05-2008 12:43 PM
