And who said mains voltage it 240V LoL
I just find this interesting:
Re: And who said mains voltage it 240V LoL
Perfectly normal. The voltage will vary depending on the load on the network and how it s being distributed around the UK. The normal range is 216V -> 253V and all equipment is designed to cope with such.
http://www.russandrews.com/article-4.-Voltage-and-Frequency-Variations-pgfrequency.htm for more details.
Also your UPS will adjust the voltage to 240V anyway.
Fixes: 16
Which is also why sensitive electrical/electronic equipment should be plugged into a spike/surge protector.  Wink
alanb
The 240 volts is a nominal figure, but is supposed to be kept within a +6%/-6% tolerence at the point of supply.
However, to make things a little more complicated, (or interesting?) UK generators are supposed to be reducing the voltage by one volt per year until it becomes a nominal 230 volts +6%/-10%, in order to meet an EU harmonisation requirement. (The rest of Europe meanwhile is supposed to increase at one volt per year from 220 volts until they reach 230 volts!)
alanb
Making things more complicated (or interesting), part two ...
My earlier post is not quite correct. The UK is moving to 230 volts +10%/-6% while the rest of Europe moves to 230 volts +6%/-10%. It appears that someone in the UK wasn't happy and bleated, so a typical EU fudge with introduced.
This effectively means nobody has to change their voltage to 230 at all, if they don't feel like it.  Cheesy And here was I thinking all those "red lines" that the British Government keep waffling on about are for something important.  Grin
Fixes: 81
All in all it still hurts when it runs up your arm Shocked
Customer and Forum Moderator.
netherfield
And this why it's called Alternating Current.
It is called alternating current cos it alternates between +240 and -240 50 times a second so therefore the poor electrons never actually get to go anywhere. LoL.
itsme
240 is the RMS and as such is not negative.
I know. I remember it well from A-Level Physics. Was just trying to keep it simple. Smiley
pierre_pierre
Quote from: Strat
It hurt an EDF worker even more two days ago in Chelmsford all 132000 volt of it, still haven't put the pieces of the substation back together
It is definitely a dangerous thing. I got hit a couple of times from the mains in an old job but was wearing rubber soled boots and not in contact with anything else at the time so it was obviously not the full force. Was very nasty all the same and a cup of tea was required!
pierre_pierre
Theve found some bits http://news.bbc.co.uk/1/hi/england/essex/7393218.stm Lips are sealed Undecided Embarrassed
look at other relevent story links on page - right
Fixes: 10
Quote from: Sean
Which is the very reason I've never understood the plug wiring convention. Why have Live and Neutral in the first place? Mains powered items don't know the difference and electronic devices step it down and rectify it anyway.
Whats the point eh? Huh
pierre_pierre
Because strangely, (but dont try it with a finger) the neutral line is as near as dam it at the earth level and the Live line fluctuates + an - about that  Cool
