Ancient Hardware
- Re: Ancient Hardware
Ancient Hardware
17-02-2021 12:18 PM
I have a really old Samsung Netbook N210 plus 2GB of RAM. I have been using it ofr around 2 years as a dedicated music server running Windows 10. I's useless for general purposes but up to now has been fine for this purpose. it's started to be more unreliable so I think it might be about to expire. I naively thought I could pick up a second hand windows laptop/netbook that was about 5 years old for not very much money second-hand or refurbished but am struggling to find anything.
Any recommendations for buying cheap second-hand PCs?
17-02-2021 1:01 PM
17-02-2021 2:08 PM
@the_groundsman wrote:
Hi 2nd hand/used laptops have increased in value quite a lot since children have been working from home
What size do you require with what processer /RAM /hard drive and how much do you want to pay
HD
17-02-2021 2:39 PM
Do you mean PC in the conventional way or Laptop? Have you thought of using a NAS or even repurposing an old PC base unit into a NAS? See https://www.howtogeek.com/190835/how-to-turn-an-old-pc-into-a-home-file-server/
Is your current netbook struggling because it's trying to run Win 10? If so have you considered taking Win 10 off and installing Linux? I recommend the Cinnamon version of Mint 20 as it's very easy to use and the desktop is very similar to Windows.
17-02-2021 5:37 PM
Thanks for the input. I'm not averse to Linux in fact i used to have lubuntu on this netbook for a while when i used it to access the internet. The issue is that it crashes from time to time so I suspect there is an intermittent hardware fault that is only going to get worse. I have around 120 GB of music and a media server on there so I have considered a Linux based music os like Daphile but found windows ran OK so reverted to that.
I could get a Raspberry PI based solution for around £100-£120 so i guess thta the budget but prefer the flexibility of Laptop/netbook with a screen and keyboard. I do like to tinker a bit so it easier to install updates and plugins that way. Therefore the spec would be a HDD of at least 150GB, 2 GB of RAM. Processor type and speed isn't an issue given what I'm using it for.
EBay looks full of junk - so I'd be concerned that stuff wouldnt work. I was really wondering if there were any reputable refurbishers out there but the refurbs I found are only selling on quite pricey machines with modern specs.
I think it will the RPi or a microPC like this, Though I would need to have a keyboard mouse and monitor on hand for updates.
Thanks for your input
17-02-2021 7:16 PM - edited 17-02-2021 7:18 PM
If you are "not averse" to Linux.... and want the use of a Windows operating system... Preferably an earlier one than W10... such as W7 or even earlier....
Have a go with ZORIN15... download.. install... then run "any" windows type program... e.g. Irfanview... ZORIN will autormatically download and install WINE 6 or whatever is the latest version... once that has been done.. it then installs the windows type program you tried to install using the normal windows .exe file......
after that.. it`s "almost" like windows in use ! ..#
Also. what about the problem being associated with an OLD HDD ? perhaps a new one will improve things ? ? ?
17-02-2021 7:33 PM - edited 17-02-2021 7:35 PM
@shutter Zorin 15.3 does not include WINE by default - but it is available in the Software Centre.
OOps - sorry misread your post. Ignore me, @the_groundsman - most people do, anyway.😀
17-02-2021 9:24 PM
@jab1 Hee Hee...... (gotcha ! ! ! )
