An Email problem
- An Email problem
An Email problem
15-05-2009 8:10 AM
Just recently, OK...... I'll blame the grandchildren !!
I've lost the ability to open links on Email messages that are sent to me.
When I click on the blue typed link sites nothing happens it doesn't open or forward me to the sites.
How do I rectify please?
Roy.
Roy.
3 REPLIES 3
Re: An Email problem
15-05-2009 10:19 AM
Try this:
Assuming you're using IE as your browser, open IE and go to Tools>Internet Options>Programs
Make sure that IE is set as default and that your e-mail program is shown against e-mail in the list of programs.
You may also have to check the security settings in your mail client (If it's Outlook Express then go to Tools>Options>Security). Try using the "Internet Zone" as the security level.
15-05-2009 7:53 PM
Thank you Kind Sir,
Redid my security levels and all seems to be back to normal.
From the Saltire I take it I was responded by a fellow Scot.
Sooooooo...... large Glenfiddoch on the mantleshelf awaits.
But don't wait too long...... evaporation, accidents or just plain thirst
may occur!!
Roy.
may occur!!
Roy.
15-05-2009 8:31 PM
Yep another Scot!
Glad you got it sorted.
Paul
Paul
