Amazon apps
HairyMcbiker
All Star
Fixes: 21
Amazon apps
Does anybody have the appstore & the Amazon store app installed and working?
I ask as I recently installed the store app, and now my appstore is returning a page not found when launching.
12 REPLIES 12
w23
Fixes: 4
Re: Amazon apps
appstore?
Call me 'w23'
HairyMcbiker
All Star
Fixes: 21
Re: Amazon apps
The Amazon appstore app. HERE
Kremmen
Fixes: 5
Re: Amazon apps
Why can't a company the size if Amazon get into the Google Appstore?
I don't like jumping hoops to install apps.
Let's be careful out there !
HairyMcbiker
All Star
Fixes: 21
Re: Amazon apps
They don't wan to pay Google, this way they have an income stream from the apps.
I use it 'cause they have a FREE app every day, got quite a few decent ones for free.
w23
Fixes: 4
Re: Amazon apps
Sorry, wasn't certain you meant the Android app.
I've certainly had it working (probably still is but I don't use it much) on my tablet.
Google probably won't allow a competing appstore to be installed via their store.
Call me 'w23'
Strat
Fixes: 565
Re: Amazon apps
You have to 'Allow Unknown Sources' on your phone to let in Amazon apps.
I had to do this to allow the 'Amazon' app to update.
Once it was done I turned off  'Allow Unknown Sources'  as otherwise it's a potential security risk.
HairyMcbiker
All Star
Fixes: 21
Re: Amazon apps
I know I have had it running for years!, but since I installed the store app it has stopped.
w23
Fixes: 4
Re: Amazon apps
I'd need to check but I think I installed both at the same time.
Call me 'w23'
HairyMcbiker
All Star
Fixes: 21
Re: Amazon apps
I had both installed but this morning the store app was working but the app app wasn't.
Have uninstalled it but my apps are still working (probably 'cause the store app does the DRM), will try re-installing later.
C1Rider
Re: Amazon apps
FYI.
The Amazon app on my Ubuntu phone works fine.
Regards..
HairyMcbiker
All Star
Fixes: 21
Re: Amazon apps
Yes but do you have BOTH the Amazon store and app-store apps installed? I can't even re-install the app-store at the moment.
C1Rider
Re: Amazon apps
Quote from: Hairy
I'm awake now..  Smiley
This mobile site does not currently support the purchase of this item. Add it to your Wish List and you can view and purchase it from your computer.
That's the prompt from my phone when viewing [ appstore ] and also
Only available for Android
Time to go back under my stone  Embarrassed
Regards..
