Amazon apps
- Re: Amazon apps
Amazon apps
30-06-2015 10:25 AM
I ask as I recently installed the store app, and now my appstore is returning a page not found when launching.
Re: Amazon apps
30-06-2015 10:40 AM
Re: Amazon apps
30-06-2015 10:52 AM
Re: Amazon apps
30-06-2015 11:05 AM
I don't like jumping hoops to install apps.
Re: Amazon apps
30-06-2015 11:11 AM
I use it 'cause they have a FREE app every day, got quite a few decent ones for free.
Re: Amazon apps
30-06-2015 11:11 AM
I've certainly had it working (probably still is but I don't use it much) on my tablet.
Google probably won't allow a competing appstore to be installed via their store.
Re: Amazon apps
30-06-2015 11:12 AM
I had to do this to allow the 'Amazon' app to update.
Once it was done I turned off 'Allow Unknown Sources' as otherwise it's a potential security risk.
Re: Amazon apps
30-06-2015 11:15 AM
Re: Amazon apps
30-06-2015 11:22 AM
Re: Amazon apps
30-06-2015 11:29 AM
Have uninstalled it but my apps are still working (probably 'cause the store app does the DRM), will try re-installing later.
Re: Amazon apps
30-06-2015 11:11 PM
The Amazon app on my Ubuntu phone works fine.
Regards..
Re: Amazon apps
01-07-2015 9:57 AM
Re: Amazon apps
01-07-2015 3:40 PM
Quote from: Hairy Yes but do you have BOTH the Amazon store and app-store apps installed? I can't even re-install the app-store at the moment.
I'm awake now..
This mobile site does not currently support the purchase of this item. Add it to your Wish List and you can view and purchase it from your computer.
That's the prompt from my phone when viewing [ appstore ] and also
Only available for Android
Time to go back under my stone
Regards..
