Amazon Music
sultana
Amazon Music
Not really sure which section would be best for this so...
I’ve had an Echo Dot for well over a year and to be fair it has served it purpose reasonably well as a radio during that time.
Last week we decided to give Amazon music a try as it’s a 1 month free trial but, tracks stutter quite frequently, radio is ok just not the streaming of Amazon music is the problem.
Whilst perusing the internet for an answer to this, one suggestion was to change the frequency from 2.4Ghz - 5 in the router settings alas, it’s still stuttering throughout. Now I know many of you have streaming services and some use Amazon hardware.
Have any of you had similar issues and resolved it?
Moderators Note: Post tidied up to make it readable.
5 REPLIES 5
TeeGee
Seasoned Pro
Re: Amazon Music
The first suggestion I would make would be to log into Amazon on another wifi device and see how it is there.
You could perhaps download the app Netgear wifi Analytics which will check wifi strength and how many others using the same channel anywhere in your house.
Fixes: 418
Re: Amazon Music
@sultana
Amazon music download music at higher quality than radio programmes. These need a faster internet connection..
Check the speed that you are getting by locating a wireless device/computer close to your echo and do a download speed test using the same wireless  link (but not both together, disconnect the echo first). You need at least 1.5 Mbps.
If you have speed problems then come back for further advice.
sultana
Re: Amazon Music
The difference in speed between my Living room, where the router is situated and the kitchen, where my Echo sits is about 70%. Distance is only about 25ft or so.
Anyway, after some reading and advice from another forum, I’ve bought a WiFi repeater/extender, seems to be working ok. Time will tell.
Mook
Seasoned Champion
Fixes: 9
Re: Amazon Music
So @sultana I guess that'll be your currant advice Grin
sultana
Re: Amazon Music
Speed in my living room is pretty stable @ around 40Mpbs but in the kitchen it fluctuates between 14 and less than 1Mb.Extender having made little difference
Pretty frustrating when the distance between a good speed and not is less than a couple of feet.
