Amazon Kindle
- Amazon Kindle
Re: Amazon Kindle
04-01-2011 4:20 PM
Re: Amazon Kindle
15-01-2011 1:12 PM
Re: Amazon Kindle
15-01-2011 2:06 PM
It only does black and white so I guess it may not be much good for reading the times as all the pictures will appear in black and white.
This is the third version of the Kindle so I guess there will be more updated versions in future but it's hard to see what can be added (except colour) The Menu includes an experimental section which allows you to connect to google & your e-mail but in my opinion it's very poor and you are unlikely to use it for that purpose, so that might be something that sees improvement in the future.
Battery life is excellent.........3 weeks between charges.
Finally check out the reviews of the Kindle on Amazon as they might help you make up your mind but for around £100 it's good value in my opinion.
Re: Amazon Kindle
15-01-2011 6:31 PM
I've downloaded a couple of Sci-Fi books for free but Amazon has over 1/2 a million available titles on a whole range of subjects.
There are loads of newspapers.
Re: Amazon Kindle
15-01-2011 6:43 PM
My book is full of colour pictures, cant imagine it in black and white
Re: Amazon Kindle
16-01-2011 6:56 PM
I read a lot of academic papers, and these days most are downloaded from databases in PDF. Currently I use a 12" (1024 x 768) Tablet PC, which is very usable as a reader in portrait format - but its getting long in the tooth, battery life is getting short and its a bit heavy to hold.
I have looked at the Kindle, and its ilk, as a possible replacement, but have only ever seen them demonstrated with the amount of text/page you get in a typical paperback (A5?). I would like to know how well they deal with - and the readability of - an A4 PDF page. Do you end up scrolling around the page as you tend to have to do with a normal landscape laptop . Could I also mark up the page as I'm reading it as I can with the tablet? Presumably I would need to download them to a PC and transfer them across.
Re: Amazon Kindle
10-02-2011 1:31 PM
Re: Amazon Kindle
10-02-2011 2:03 PM
Scrolling around is bad enough on a conventional landscape monitor.
Re: Amazon Kindle
11-02-2011 5:39 PM
Edit: Another source of free books is the Gutenberg Project, you need the .mobi files.
Re: Amazon Kindle
23-02-2011 11:02 PM
One of the best features is the synchronisation element - you can read some on the Kindle, then later continue reading where you left off on the PC, and then switch to the iPhone (and I was really surprised by just how readable the Kindle app is on the iPhone) - as long as each has some form of connectivity, there's no messing about with bookmarks, etc.
There's a rudimentary browser included, but whilst it's ok for (very) basic use, don't expect 100% support of modern web standards - e-ink transition isn't really fast enough yet to support moving graphics, for example.
The Kindle has it's own email address to send files to. In fact, it has two:
user@kindle.com - converts the attached file and sends it to your Kindle, but you will incur a charge if it goes over 3G.
user@free.kindle.com - does exactly the same, but restricts to only sending over Wifi, so you don't incur any charge.
A useful application is Calibre which enables you to build a library of ebooks, download book data from the web, convert formats and load onto your Kindle. It also has a scheduler which will pull down from a wide selection of periodical-type websites, convert the formats and transmit to your Kindle.
I'm sure other devices will come along in the future, but for now at least, the Kindle is way out in front as an ebook reader.
Re: Amazon Kindle
23-02-2011 11:57 PM
Quote from: wisty Thanks - sounds like something I will avoid.
The latest firmware update to 3.1 which my Kindle has just this minute installed for itself is supposed to offer, amongst others, easier scrolling around large documents.
Re: Amazon Kindle
24-02-2011 5:33 PM
Re: Amazon Kindle
03-03-2011 2:27 PM
Quote from: Bob Chris already has one of these, and I was looking to pick one up for my birthday in a couple of month's time. Interested in hearing peoples' feedback.
Picked one up a couple of weeks back. Not had much time to play around with it yet though. I still have about five conventional books to get through first!
Re: Amazon Kindle
03-03-2011 2:31 PM
Quote from: A What's wrong with trying to read a real book?
Think of the trees!
B.
Re: Amazon Kindle
05-04-2011 8:26 PM
When I have got this wifi bit sorted I will be very pleased with it.
