Amazon Fire Stick not connecting
Kinvara5
I’ve had an Amazon Fire Stick for 10 months and its being working without any issue, but this week it started to drop connection. I’ve trawled through all the message boards and after trying everything decided to restore factory settings. Now in the process of setting it up again and it won’t connect to the WiFi. I’ve tried to connect by password and WPS and not get the message, could not contact amazon.co.uk, please check router or another wireless network.
All my other devices (phone,iPad) are connected to the WiFi
Anyone have any suggestions?
4 REPLIES 4
Fixes: 480
Re: Amazon Fire Stick not connecting
Is it connecting to your router? Go into your router's admin settings by putting 192.168.1.254 into the address field of your web browser then enter the router admin password as found on a label on the router. Select the My Network tab and see if the firestick is connected.
As other wireless devices work OK I would suspect that the firestick is playing up. Have you tried both restarting the firestick and resetting the remote control by removing the batteries for a minute or so?
Gel
Champion
Fixes: 29
Fixes: 1,664
Sorry to hear you're having problems with your Amazon Firestick.
My advice would essentially be what @Baldrick1 has said.
Let us know how it goes.
Mav
Fixes: 518
Moderator's note:
Thread moved from Broadband to Tech Help.
Forum Moderator and Customer
