Amazon Echo and Philips Hue
FIXED- Subscribe to RSS Feed
- Amazon Echo and Philips Hue
06-10-2019 12:44 PM
I have an Amazon Show 5 and a set of Philips Hue LEDs strips and I'd like to sync the lights to the music playing on the Show. I've looked around and created the required 'Entertainment Zone' but I can't find out how to actually start there is nothing obvious anywhere that I can see, either that I'm missing the obvious.
Just in case it makes a difference the output of the Show 5 is connected to my Amplifier.
Fixed! Go to the fix.
06-10-2019 1:26 PM
@Anonymous
Maybe Alexa is a tad different, but I have a Google Home setup (hubs, nest doorbell, nest thermostats etc), with a Phillips Hue Light setup and the entertainment zones only seemed to work when using the PC Desktop Hue app - which seems weird, but it would only work plugging my laptop into a HDMI port and running whatever from there.
They're releasing a new Philips Hue box to allow syncing with anything, and charging a lot of money to do something that should have been present in their current setup, especially as everything connects up to the Bridge.
Re: Amazon Echo and Philips Hue
06-10-2019 1:38 PM
Thanks for the reply @JOLO, when following the resource I found on the Internet regards the 'Entertainment Zone' it went on to mention installing the Hue App on the PC / Mac so I guess this is the only way it can be done (hopefully for now).
