Amazon Echo Spot
Mayfly
All Star
Amazon Echo Spot
Does anyone know if you can use 2 Echo Spot as cctv set up?
I know you can video call on them but I need a cctv and for the cost of a camera that works with the ES I can almost buy a second Echo Spot.
1 REPLY 1
VileReynard
Fixes: 20
Re: Amazon Echo Spot
Everyone should send their CCTV recordings to Amazon.
