Amazon Echo Spot
- Re: Amazon Echo Spot
Amazon Echo Spot
02-12-2018 2:27 PM
Does anyone know if you can use 2 Echo Spot as cctv set up?
I know you can video call on them but I need a cctv and for the cost of a camera that works with the ES I can almost buy a second Echo Spot.
1 REPLY 1
03-12-2018 9:29 PM
Everyone should send their CCTV recordings to Amazon.
