Am I missing something?
ArthurDent
Decided to try to tidy up, and neatly mounted the openreach fibre box on the wall. Aiming to do similar with the plusnet/technicolor router I find that the keyholes on the back are the wrong way up, so that if you use them then writing etc on the front is upside down. a design booboo?
Surely this has been posted here before?
1 REPLY 1
jelv
Fixes: 10
Re: Am I missing something?
Thank your lucky stars you don't have one of the new ones. It has key holes for wall mounting but the Ethernet cables come out of the back so you'd have to hack a hole in the wall for the cables it you tried to wall mount it! (But they did get the writing the correct way up)
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
