All4
gleneagles
Aspiring Legend
Fixes: 17
All4
Never had a connection problem with All4 until yesterday, since then have been getting the message on the tv..
There has been a problem connecting to All4. Please try again later.
So clearly a problem at their end but if any of you get All4 are you getting this same issue .?
Just wondering if it’s a local problem or it’s down everywhere.
Not been able to find any info about this on the internet.
Thanks.
We are born into history and history is born into us.
4 REPLIES 4
shutter
Fixes: 67
Re: All4
@gleneagles    Dunno..... just google search... "is there problem with All4"
got this
https://www.downtoday.co.uk/channel-4-on-demand/
Dunno if this site will help.....
https://easyfixpro.com/all-4-not-working-on-smart-tv/
RobPN
Fixes: 15
Re: All4
Wouldn't it have been more useful / simpler to try it on one of those three smart TVs you said you had not long ago @shutter ?
@gleneagles
I've not used All4 for ages, but after doing a password reset and logging in I tried it for you on my Samsung TV.
It worked fine, the selected episode of 'Brass Eye' started playing after a couple of ads and ran OK for a few minutes until I stopped it.
HTH
gleneagles
Aspiring Legend
Fixes: 17
Re: All4
@RobPN @shutter
Thanks for the responses.
I have a LG tv. The settings option informs me everything is up to date and is set on automatic update.
The tv is about 7 years old so not sure if that has any relevance, tried to get All4 on my tablet which just gives me a message  that ‘ something went wrong’
Typical that I was halfway through a series (Cry Wolf).
Seems from comments others have had problems but they sound more like connection problems.
gleneagles
Aspiring Legend
Fixes: 17
Re: All4
Contacted All4 and they were quick to get back to me with various suggestions what I needed to do was reset the tv back to its basic settings and go through the menu to set everything up, during that process All4 gave me a option of updating which was not previously available, so everything is up and working fine now.
Happy days.
