Albums to CD
- Albums to CD
Albums to CD
06-10-2009 5:37 PM
Re: Albums to CD
06-10-2009 5:48 PM
Re: Albums to CD
06-10-2009 6:00 PM
I did all this about 15 years ago, using a decient turntable, amp and the line input of my SoundBlaster card. Also transfered a load of cassettes the same way.
Manually cutting the tracks and naming them was laborious....
Re: Albums to CD
06-10-2009 6:17 PM
Re: Albums to CD
06-10-2009 7:37 PM
Quote from: valart I am not sure which forum deals with this but here goes.I have so many wonderful record albums and I would like to put them on CDs my computer does not have a cd writer or a burner,I noticed that you can buy a record player with burner inside,the idea would be to download them onto my ipod.
If you are using an ipod or similar mp3 player, you don't need CD's.
You just need to store your audio in a high quality format (on your hard disk) - this can then be converted into mp3 format.
Is it possible to use the aux output of your hi-fi to feed into your sound input socket on your sound card?
Then use some recorder software to create a large file for conversion to mp3.
Re: Albums to CD
06-10-2009 8:11 PM
Quote from: Be3G I should caution that I've heard the sound quality of the USB turntables can be quite dire.
Agreed.
I returned a Veho Music Lab USB Turntable to Amazon last year as it proved to be no more than a toy.
Re: Albums to CD
07-10-2009 9:35 AM
I believe poppy has done something similar recently, you may want to ask her.
The hardest part is splitting an album in to songs I found. It is easier to record one side and use something like audacity to convert it by splitting rather than doing individual tracks. Just takes time and effort.
Re: Albums to CD
07-10-2009 11:06 AM
But it proved a false economy. The Veho deck had a tiny motor which fluttered so much it produced an output which was almost unrecognisable from the original. My albums are now all gone, donated to a charity shop before I moved home, and I still haven't got round to downloading a single track since
Re: Albums to CD
11-10-2009 3:24 PM
Re: Albums to CD
11-10-2009 3:38 PM
It is a bit like the Video->Dvd->Blue Ray. I bought a lot of Dvd copies of Video's I already owned but no way am I going down the BR route and re-purchasing them.
