Akamai Netsession Client
- Akamai Netsession Client
19-08-2013 6:18 PM
My pc had been fine except for a Zone Alarm warning that something like Setup something or other was trying to run. Googling came up with this being a Zone Alarm fault, and to delete ZA and re-insert it. Doing that brought up the warning about Akamai Netsession Client
I can start the pc in Safe Mode, and I tried a System Restore from 2nd August but that hasn't sped anything up. My OS is XP, machine is a Dell 775.
Thanks in advance
Re: Akamai Netsession Client
19-08-2013 6:45 PM
Checking back I installed it (or agreed to install it) to download something from Microsoft (that in the end I didn't want) and forgot to remove it afterwards.
It's gone now, no problems at all.
19-08-2013 6:46 PM
19-08-2013 7:40 PM
I seem to have lost my connection to the internet. I know the modem is working because the pc I am using to write this is using that modem. On my faulty pc, I can boot up into Safe Mode with no real problem, but if I try to select Safe Mode with Network Connection (the faulty pc is hard-wired to the modem), the pc stops at the equivalent point where it stops when coming up normally, that is the point where icons should start to appear on the desktop. I have tried rebooting the modem too, but no improvement.
In normal mode, I get the background (green hill with blue sky) but no icons.
Is there a way to get this akamai s/w copied across to my faulty pc, then re-install it?
Thanks for any help
19-08-2013 9:30 PM
If the worst happened, and I did have to use my Win XP CD:-
(1) how do I use Repair to fix anything - Repair seems to take you into the repair process but then leave you to figure out what to do - does Repair automatically fix any XP problems, or what?
(2) If I have to do a fresh install of XP, will that wipe data stored on another partition (I have two partitions on my hard drive, the C: drive with OS and Office, etc, and the 😧 drive with all my data files on it)? I assume I will lose all Drive C s/w, but hope not to lose Drive D s/w
19-08-2013 9:43 PM
19-08-2013 11:57 PM
(2) A fresh install of Windows (from disc) will only wipe the partition you choose to install it on. So you could lose your data but only if you were careless.
No icons means Explorer is not running. You could try using Ctrl Alt Del to start Task Manager and use that to run Explorer. I have seen partially removed viruses that cause this symptom.
20-08-2013 8:54 AM
20-08-2013 9:35 PM
How do you deal with a partially removed virus?
At the moment, I am in Safe Mode trying to move all data over to an external hard drive. It is taking a long time, but I should get it somewhere safe.
Will let you know how I get on. In the meantime some guidance on Task Manager, and partially removed viruses would be helpful please
21-08-2013 7:56 AM
Quote from: penneck My pc had been fine except for a Zone Alarm warning that something like Setup something or other was trying to run. Googling came up with this being a Zone Alarm fault, and to delete ZA and re-insert it.
This is an object lesson to demonstrate why ZoneAlarm does most people no good whatsoever. However:
Try an offline virus scanner. Kaspersky have one, Microsoft have one http://windows.microsoft.com/en-GB/windows/what-is-windows-defender-offline and I'm sure there are others. If the action of Ctrl Alt Del to start Task Manager does not work then you almost certainly have a virus.
21-08-2013 6:20 PM
Having seen your post, I have Googled Windows Defender Offline, but it says it needs XP to be at SP3, whereas my CD is only at SP2, so I dont know if Defender will work. My PC was at SP3 before the fault started.
I have also "saved" a download of Kapersky on a 30-day trial using this pc, but how to I get it prepared and onto a CD. It is an exe file, but do I have to run it to open it to produce the necessary files, then get them burned onto a CD?
21-08-2013 8:48 PM
22-08-2013 7:11 PM
Also Internet Explorer is only Version 6
Any suggestions?
22-08-2013 8:07 PM
It is possible to download and keep XP SP3 and you can also find IE8 for XP on the Microsoft Download centre website.
If you had a boot sector virus, you would need to wipe the entire drive, not just one partition, but I'm not convinced you had a virus, it could just have been ZoneAlarm and all the installing and uninstalling breaking the system.
22-08-2013 9:01 PM
As for Windows Update, if I have understood correctly what I read on the Microsoft web-site just before I came back to the Forum, the Windows Update will act at a time that is set by me - I've just found it was set at 03:00, so I have changed it to 21:00, and hope to get the updates any minute now
