Airplay being blocked by tg582n router?
Alexburton
I am trying to use philips fidelio wireless speakers. The speakers are connected to the wireless and so is my ipad. I can play music through the philips app on the ipad to the speakers, but the apple airplay feature won't activate at any point. I have been on a few different forums and people are talking about the router causing the problem. They recommend updating firmware on the router turning of something called qos or unblocking ports.  I am willing to try any of these but don't know how to do it. Can you help?
So far I have tried updating all software on speakers and ipad. Turning off the firewall on the router and a lot of switching off and on again. I am going to try and take the  speakers to a friends and try on a different router but not sure when I will get chance to do this.
Thanks,
Alex
1 REPLY 1
pcathomerepairs
Re: Airplay being blocked by tg582n router?
these are the airplay ports need
http://bowersandwilkins.custhelp.com/app/answers/detail/a_id/55/~/firewall-ports-utilised-by-airplay
your router has upnp media server as well this may work better
acording to the manual
http://help.demon.net/files/2013/03/TG582n-User-Guide.pdf
