Airplane mode ? ?
- Re: Airplane mode ? ?
Airplane mode ? ?
03-08-2015 6:23 PM
can somebody please enlighten me........ when I clicked on it.... (somewhere) it shut off my WIFI connection to the router !...
03-08-2015 6:24 PM
03-08-2015 6:26 PM
03-08-2015 6:34 PM
ah yes........
turn off the wifi ( for use when on aeroplanes etc. )
03-08-2015 6:39 PM
York.
03-08-2015 6:57 PM
03-08-2015 7:59 PM
03-08-2015 8:01 PM
Quote from: shutter turn off the wifi ( for use when on aeroplanes etc. )
Because that would be rather long wouldn't it.. and we all know most airlines don't like passengers using any radio transmission equipment (you especially should know) and so it's called airplane mode for that reason - because all radio transceivers in the device are turned off.
Be grateful you can still use the apps etc while its activated (as long as they don't need the internet)
03-08-2015 8:07 PM
The last time I flew it was in a VC10 B.O.A.C to Mauritius ( and back 2 years later )... I didn`t have a laptop or mobile phone at the time... so wouldnt know about the wifi regs... !
03-08-2015 8:08 PM
York.
03-08-2015 8:11 PM
03-08-2015 8:25 PM
@Strat.... yeah... shudda gon Yokshu Airlines....
