Advice required please [Solved]
- Re: Advice required please
23-03-2016 3:40 PM
03.23@15:23 ++ Launching mintUpdate
03.23@15:23 ++ Starting refresh
03.23@15:23 ++ Initial refresh will happen in 10 minutes, 0 hours and 0 days
03.23@15:23 ++ System is up to date
03.23@15:23 ++ Refresh finished
03.23@15:33 ++ MintUpdate is in tray mode, performing initial refresh
03.23@15:33 ++ Starting refresh (including refreshing the APT cache)
03.23@15:33 ++ Auto-refresh will happen in 0 minutes, 2 hours and 0 days
03.23@15:33 ++ Error in checkAPT.py, could not refresh the list of updates
03.23@15:36 ++ Starting refresh (including refreshing the APT cache)
03.23@15:37 ++ Error in checkAPT.py, could not refresh the list of updates
23-03-2016 4:21 PM
23-03-2016 4:43 PM
sudo apt-get clean
sudo mv -v /var/lib/apt/lists /var/lib/apt/lists.broken
sudo mkdir -p /var/lib/apt/lists/partial
sudo apt-get update
23-03-2016 4:46 PM
Failed to fetch http://dl.google.com/linux/chrome/deb/dists/stable/release
Unable to find expected entry 'main/binary-i386/packages' in release file (Wrong sources.list entry or malformed file)
some index files failed to download They have been ignored, or old ones used instead.
23-03-2016 4:53 PM
As long as the rest are loading you could try #'ing out the chrome repo for the moment.
23-03-2016 4:55 PM
23-03-2016 4:55 PM
Can you advise where the spaces should be in those lines as despite a few guesses I get the message, command not found when inputting the second line.
23-03-2016 5:01 PM
23-03-2016 5:04 PM
Quote from: ejs Has Google stopped producing Chrome for 32bit Linux yet?
Do you mean this ? - How To Fix The (Annoying) ‘Failed to Fetch’ Chrome apt Error
23-03-2016 5:09 PM
Quote from: gleneagles sudo: mv-v /var/lib/apt/lists/var/lib/apt/lists.broken: command not found
mv <space> -v <etc>
23-03-2016 6:27 PM
‘/var/lib/apt/lists’ -> ‘/var/lib/apt/lists.broken/lists’
23-03-2016 8:12 PM
However, you are supposed to be moving /var/lib/apt/lists to /var/lib/apt/lists.broken
So you should be getting a message
Quote '/var/lib/apt/lists' -> '/var/lib/apt/lists.broken'
Quote from: gleneagles After inputting the second line I am getting,
When running these commands, its safest to copy & paste them.
23-03-2016 8:57 PM
I will check this out tomorrow.
24-03-2016 3:57 PM
E: Could not open lock file /var/lib/apt/lists/lock - open (2: No such file or directory)
E: Could not open file descriptor -1
E: Unable to lock the list directory
At least it gives me something to do
24-03-2016 4:24 PM
sudo su -c "apt-get update"
sudo su -c "dpkg --configure-a"
sudo su -c "apt-get -f install"
