Advice please about IPhone
- Advice please about IPhone
27-07-2015 5:40 AM
I have an android phone which is several years old. As most of my stuff is apple PC, iPad etc I am going to upgrade to an iPhone when the new one comes out hopefully this September. As my eyesight isn't so good I am going to get the one with the larger screen as I believe it will be better viewing for me. I am wondering if because the screen is larger do they fit in your pocket OK. I normally put my phone in my front trouser pocket with no problems. Is there any other problems I should be thinking of. What size ram is advisable etc?
Thank you
Gordon
Thank you
Gordon
4 REPLIES 4
Re: Advice please about IPhone
27-07-2015 8:11 AM
you mean the iPhone 6 or the 6 Plus?
the 6 Plus is huge and will struggle to sit well in a pocket (see "bend gate").
the 6 is still quite big so it'll depend on your pocket.
you don't get a choice of RAM with iPhones, are you actually talking about storage size?
general rule is get the best one you can afford.
27-07-2015 10:31 AM
sorry for being so vague chenks but I am 76 year old just a youngster these days However I am not that clued up on them. must admit I read somewhere about the bend factor. And yes I probably am thinking about storage factor as I shall want to keep some family photos on it. Fortunately or unfortunately depending how you want to look at it because of glaucoma (controlled by eye drops) I decided to give up my car so the money saved on not having a car/insurance/tax etc can be spent on the phone so will do as you suggest and get a better phone. But shall wait till the latest one comes out possibly in Sept/Oct
thank you
Gordon
thank you
Gordon
27-07-2015 10:35 AM
the iphone does have accessibility features for making text larger.
might be worth going into an apple store and playing with one so you can see which is better.
27-07-2015 10:59 AM
