Advice needed regarding upgrades
- Advice needed regarding upgrades
- « Previous
- 1
- 2
- Next »
Re: Advice needed regarding upgrades
05-04-2009 8:50 PM
Quote from: BlueRhizome
Quote from: Samuria If the game uses a cd/dvd coping this to the hd may help as if the cd and hd are both running its more heat
Is there a particular method for copying the cd-roms onto the hd or is it just copy and paste?
Tried the copy and paste method, but this does not seem to work. Any ideas?
05-04-2009 10:58 PM
What is the game some games give the option when you install to copy all the files to hd. Some games have copy protection and need the cd.
With most games it looks for its files from the drive it was installed from or there may be an option in the game setup to change. You may have to uninstall then install from the hd.
If we know the game someone may know its options regards no cd
06-04-2009 9:04 AM
Edited - I had forgotten we were talking about a game.
06-04-2009 9:13 AM
Quote from: Samuria What is the game some games give the option when you install to copy all the files to hd. Some games have copy protection and need the cd.
The two he uses are:
Bionicle Heroes + PES 2009
I only tried the first and I get: the CD-Rom was not found.
- « Previous
- 1
- 2
- Next »
