Advice: PC to TV Wireless
jojo
Just looking for some advice as ive been hunting on the internet for a very cheap but good wireless audio/video pc to tv converter. Some I have found but then realised its only for tv. At the moment I am using S-video and audio cable 10 m of them and thats with having to move my cpu nearer.. (sigh!! yep I under measured) All I am after is to stream Movies from my PC to my LCD tv without having to uplift anything or run wires...
scootie
Re: Advice: PC to TV Wireless
you not got a ps3 or xbox? these do this job
jojo
Nope!!  Im a PC Gamer  Cheesy
scootie
how much are these av senders your looking at maybe cheaper to pick a 2nd hand ps3 or xbox up to stream your movies that way
jojo
well cheapest one, thought i found one for like £15-40 but i think they was just tv to tv.. So realy looking for something dirt cheap... Ive just had an idea  Crazy  lol how about setting up my other cpu into to the tv as my router is by the tv and has 4 sockets to attach 4 diff comps hmmmm  Roll eyes
scootie
sounds good. i some times use the laptops on my 32inch samsung but one only has vga and my other dell has a decent enough card in it and a hdmi connection
the vga is pants and iplayer has v-sync problems, but the hdmi dell is tip top
Vip3r
Hi Jojo
If you can already connect your PC to TV via composite then a standard TV sender should work, all you need is one that has the Video and L/R Audio inputs (RCA Phono) rather than a scart .
jojo
Scrap the idea of using my other comp... lol fan was too loud would be too annoying...  Hey!!  Viper, been trying to look for one with those inputs but all i done was confused myself  Crazy  I have a Inspiron 530  with the tv tuner looked on ebay and found this but still unsure if im looking for the right thing
http://cgi.ebay.co.uk/Logik-Wireless-Wi-Fi-Audio-Video-AV-Sender-Receiver-Kit_W0QQitemZ370280498223Q...
My experience of those 2.4Ghz AV senders is that they interfere with wifi (they're on the same frequency).  The are other that work on a different frequency, but they're more expensive.  Sad
Vip3r
It should work, but you might need a few more things:
you might have one of these already:
3.5mm Jack to 2 x RCA Phono Stereo Audio Cable
http://www.amazon.co.uk/3-5mm-Phono-Stereo-Audio-Cable/dp/B000Q6LSWM/ref=sr_1_11?ie=UTF8&s=electroni...
and you will need something like this (not sure if phono to Svid is the same as svid to phono though.):
RCA/Phono Socket to SVHS/S-Video Male Connector - Gold
http://www.amazon.co.uk/Phono-Socket-SVHS-S-Video-Connector/dp/B000E3K4QI/ref=sr_1_2?ie=UTF8&s=elect...
[Edit]
OR: StarTech.com 6 inch S-Video to Composite Video Adapter
http://www.amazon.co.uk/StarTech-com-S-Video-Composite-Video-Adapter/dp/B0000BZ2WC/ref=pd_bxgy_ce_im...
[/Edit]
Then you should be able to connect the video sender that you found on ebay.
pierre_pierre
