Advice: Free pdf creator
randpwar
I’ve taken on updating a local sporting association’s website recently whereby I receive match results and averages etc. We also put up a downloadable match / team grid from which members can establish which team they are playing in any week. This comes to me in a spreadsheet but the previous administrator tells me that he converted them to pdf to avoid members being unable to access them as they happened to have an earlier version of MSExcel. He paid about a tenner for deskpdf from docudesk.com but being a bit stingy  Wink I thought I’d try and get a free version to do the same job. A friend gave me go2pdf but that seems to create a file with a .xps (?) extention; obviously only those with an application to read these files could view the download meaningfully. Looking at the literature for pdf995 it says it takes you to the company’s website every time it’s used. Does this refer to when I use it but not when someone is viewing the website?  Anyone know of a free pdf creator that would do the job for me?
Rob
csogilvie
Re: Advice: Free pdf creator
I am assuming you are on Windows... in which case I use CutePDF and my housemate uses Primo PDF to produce PDFs and both seem to work equally well.
Fixes: 348
Also if you have office 2007 there is a free pdf save as from microsoft.
Customer / Moderator / If it helped click the thumb / If it fixed it click 'This fixed my problem'
randpwar
@cso  Thanks for the suggestions
@Adiewoo    I do have Office 2007, does this mean that I can just Save As a .xls to .pdf?  At work (well, supposedly) at the minute so can't look
csogilvie
Yeah, from memory it's on the Save As... menu, but I'm also at work and can't look Cheesy
Fixes: 348
You install a plug in and then it's save as, download from here
Works for word, powerpoint, visio, publisher etc. I have used it and works pretty well.
Fixes: 10
I use pdfcreator: https://sourceforge.net/projects/pdfcreator/
It is a printer driver and works with any program that has a print function!
jelv (a.k.a Spoon Whittler)
Mobile: iD mobile (£4/month)
randpwar
Thanks Adie....I'll give it a try when I get home
Rob
randpwar
Thanks for the replies guys  Smiley
Free add-on from Uncle Bill worked just fine  Cheesy
Rob
