Advanced settings
Manumad
Advanced settings
Can someone explain how to change the setting for my tv from 2.4 to 5 ghz. Cheers.
11 REPLIES 11
Fixes: 418
Re: Advanced settings
Welcome to the forum.
You go into your TV network settings and select the 5GHz SSID. However:
1. The TV must be 5GHz capable.
2. If you have a Hub Zero (2704n) router this has no 5GHz band.
3. If you have a Hub One you must first separate the bands, see https://community.plus.net/t5/My-Router/2-4ghz-and-or-5ghz-best-practice/m-p/1351966#M840
Strat
Fixes: 565
Moderator's note:
Topic moved from Fibre Broadband to Tech Help.
7up
Fixes: 17
Special techniques not dissimilar to voodoo are used for makes and models that nobody knows..
Dance around the room in a circle three times shouting "TV on, TV on, i like my wifi and TV on"
Then hop on the spot 5 time while spinning round..
Then jump to the TV in one step (if you do it in two or three jumps then it induces a curse upon you instead). When you land in front of the TV you then have to tap it 5 times to signify you want the 5GHz range
Once done you have to finalize the process by unplugging it, counting to 1648 - incrementing the number once every two seconds (so it'll take a while) and then when you reach that last number you have to do the circle round the room thing backwards 3 times.
You should now find that it just miraculously works!
shutter
Fixes: 65
Or not !Cheesy
Manumad
Knob !
Manumad
Thank you all sorted
shutter
Fixes: 65
@Manumad wrote:
Knob !
Hmm...  Which Knob was it that made it work then  ? Undecided
7up
Fixes: 17
@Manumad wrote:
Knob !
Says the person who didn't tell us anything about the TV in the first place such as the make or model!
At least I made an effort to spend more than 20 seconds typing which is more than could be said about you.
vultura
@shutter wrote:
@Manumad wrote:
Knob !
I remember when TVs had knobs that made them turn on/off, change channel.  None of this lounging around with a remote in hand.
Has anyone seen my signature, it's gone missing.
7up
Fixes: 17
The pleasantries of the 80s eh?!
Better times weren't they, although we got great tech these days i don't like the way society or the country is going.
vultura
Agreed.
Society seems to be too much about me, me, me and no thought for anyone else.
