Adobe
rena
Adobe
My son has been trying to watch a video on You Tube. It said he had to install the latest version on Adobe so he clicked on the download button. It appeared to be downloading normally but then when it gets near the end it says he already has that version installed. We tried again and the same thing happened. We seem to be going round in circles - he can't watch you tube until Adobe is up to date, but Adobe is up to date. Does anyone know what's wrong and how he can watch You Tube? thanks everyone
Fixes: 62
Re: Adobe
which browser is he using
Re: Adobe
I've seen various oddities with what I call "embedded" updates like that.
Try going to the relevant software web site and downloading a standalone installer (not to run in a browser) and run that.
rena
Re: Adobe
Oldjim, he is using IE.
Thank you very much for replying HP. But i'm not too sure what you mean as i'm a bit thick! Can you tell me what you mean by stand alone please? I thought I would have to use a brower like IE, Google etc to download it in the first place?
Fixes: 62
Re: Adobe
If you go to Tools, Manage Addons what does it show for Adobe
rena
Re: Adobe
Hi Oldjim, it says -
Name          Shockwave Flash Object
Publisher    Adobe Systems Incorporated
Status        Enabled
File date    03 August 2012, 17:13
Version      11.3.300.270
Name          Adobe PDF Link Helper
Publisher    Adobe Systems, Incorporated
Status        Disabled
File date    26 March 2012, 16:38
Version      9.5.1.283
Load time    (0.12 s)
Fixes: 62
Re: Adobe
Nothing obviously wrong there.
Can you try this.
Go to Add/Remove Programs in Control Panel and remove Adobe Flash Player
Then go to here http://get.adobe.com/flashplayer/ and install it again
Remember to untick McAfee Security Plus
St3
Aspiring Champion
Fixes: 5
Re: Adobe
go here http://get.adobe.com/flashplayer/otherversions download "for other browsers" this fixed mine and im also IE9
rena
Re: Adobe
Already tried that, Oldjim.  Ukste, I will give your idea a go when I get home, thanks.
Fixes: 22
Re: Adobe
I wonder if the issue has anything to do with the fact that flash version 11.3.300.268 is the version you get if you download the installer, but Adobe have released 11.3.300.270 mainly via the auto-update mechanism. The only fix in 270 is a fix for the auto updater crashing. Adobe didn't put 270 at the main download location due to "logistical issues and time constraints", and Adobe's website generally lists 268 as the latest version.
