Adobe Spark
- Re: Adobe Spark
Adobe Spark
02-05-2020 3:11 PM
I'm looking at using Adobe Spark and before I do sign-up, just wanted to get some feedback on it (or alternatives) for personal use?
Re: Adobe Spark
03-05-2020 12:18 PM
Hi @Leapy
Presumably you have looked at reviews like https://www.techradar.com/reviews/adobe-spark
Dave
Re: Adobe Spark
03-05-2020 5:04 PM
@daveplus Thanks. It does say.....
Final verdict
Even though Spark merges three services into one, they are clearly still three separate services. But despite the glitches we encountered, there’s a lot to like here, and the features will help you create a graphic, a webpage or a video very quickly. For a free service, it’s definitely worth checking out.
Re: Adobe Spark
03-05-2020 5:25 PM
