Adobe - Printing Form fields only
netreg
hi all,
after some assistance cos for the life of me i cant work it out  Cheesy
I created an adobe form at work to use at a club i attend. It has a background of a form i need to complete on regular basis and then when i choose print , i select the option print form fields only and its all ok..
however when i get on the pc at the club, it doesn't give me that option...  Is it an option that is only available in the paid version?Huh
thanks kindly.
StickyMick
Re: Adobe - Printing Form fields only
Quote from: netreg
Is it an option that is only available in the paid version??thanks kindly.
Pretty much answered your own question there.
Not sure if Foxit Reader will do what you want: http://www.download.com/Foxit-Reader/3000-2079_4-10313206.html
netreg
Doh!!!  thought it might be the case..  thanks for the tip on Foxit, the problem i have is not being allowed to install any additional software...
thanks
pierre_pierre
if you can access USB, you can install firefox etc as standalone and run it from there see http://PortableApps.com
