Adobe Flash delivers Ransomware
- Adobe Flash delivers Ransomware
09-04-2016 7:37 AM - edited 09-04-2016 7:39 AM
Just thought you should all know it has been announced that ransomware can now be delivered via Adobe's Flash Player so it is recommended that you upgrade to the latest version as soon as possible or disable it.
If you want to read more.
1 REPLY 1
Re: Adobe Flash delivers Ransomware
09-04-2016 10:19 AM
flash should auto update but once again flash is oooops
http://www.techspot.com/news/64395-adobe-issues-emergency-patch-fix-vulnerability-used-install.html
