Adobe Flash delivers Ransomware
Just thought you should all know it has been announced that ransomware can now be delivered via Adobe's Flash Player so it is recommended that you upgrade to the latest version as soon as possible or disable it.
If you want to read more.
1 REPLY 1
rongtw
Fixes: 12
Re: Adobe Flash delivers Ransomware
flash should auto update Wink  but once again flash is oooops
http://www.techspot.com/news/64395-adobe-issues-emergency-patch-fix-vulnerability-used-install.html
